ShellyJ123
we decided to DIY our plumbing in our new addition. We had a little experience but nothing prepared us for this big a task. We are getting ready for the rough-in inspection and capping all the drains and flanges. We put this sanitary tee with cleanout at the bottom of the waste stack where it goes to ground. But now we realize this will be a bit hard to get a testing balloon into.
Is there anything you all can suggest in order to block the 3" AND the 4" ?
Top and bottom are 4" the 2 sides are 3" with cleanout cap as seen on the right side of the image.
Worst case we can cut the 4" and put in a testing cleanout and same with the 3". But because it's all glued up we would have to use mechanical couplings on 1 side to put it all back together. Also this would not test the bottom joins
