Timmed
Greetings all.
I just completed a total re-pipe of my home. It had galvanized supply pipes and has been completely re-done with Uponor PEX. I used 3/4 trunks for both hot & cold, and multi-port tees at each location to distribute the 1/2 supply lines to each fixture. Wow, what a difference in both water pressure and taste!
My question is about whether I needed to use protective bushings whenever the PEX passes through a hole in the framing or subfloor. I drilled clean, straight holes, and ensured that there was enough "give" so that the pipe could move freely as it expands/contracts. I was careful to not leave sharp edges anywhere, but the pipe is definitely touching the wood.
Do I need to be concerned about a leak developing years down the road?
