Water softener waste line
Carbonxe
New Jersey
I currently have a water softener which dumps into a sump basin but I'm looking to move it to dump directly to my waste line. I'm also re-routing my sump waste line and was going to tie it into that. I have a sketch below but wasn't sure if it was sufficient enough for the water softener. Green is existing plumbing.
Would I need an AAV on the horizontal section between the P-Trap and Tee?
Any advice would be appreciated.
Old
NE
You can check with your municipality put usually draining sump discharge into the sanitary sewer is against code.
Do you have a laundry standpipe near by? Even if it's on the floor above you can run the softener drain up to the laundry standpipe and just use an air gap adapter where the softener drain enters the standpipe.
John Gayewski
Iowa
You can't pump from a sump pit into the sewer. I don't think anywhere would allow that.
Carbonxe
New Jersey
The sump is already going into the main sewer, that’s how it was when we bought the house.
Laundry is in the basement and goes to a utility sink which is also tied into the main sewer.
There are places that allow or even promote that. Even rain gutter output some places, if you can believe that. They have what is called a combined sewer system.
Chicago, Milwaukee, Boston and more have that.
John Gayewski
Iowa
John Gayewski
Iowa
Every gallon of water needs to be treated when it comes back out through the sewer. If your a municipality your cost gets reduced by many millions of dollars when they go back and seperate the storm from sanitary. Not to mention the EPA fines that are avoided.
