Giantsean
Hi All,
Noticed some water stains on the ceiling under two tubs. Investigation and a brand new access hole (thankfully through a linen closet ) led me to the culprit. The assembly is a Kohler 7213 overflow kit which was installed along w/ the tub it goes with by a licensed plumber about 2.5 years ago. I assume since the assembly can be custom cut to length that he had to glue it himself and it did not come pre-glued. Kohler has a 1 year only warranty on the assembly but that doesn't seem to be the problem.
You can see from the pics where it is leaking.. one drop maybe ever 10 seconds. I assume the best (maybe only) way to fix it is to make a cut before the joint, remove the drain assembly, glue in an extension, and then glue in and install a new drain. I did have a few questions though.
- I'm sure you guys have seen something like this before, but what causes it? He installed the tub in a mortar bed however it let go in a few places. However it does not flex excessively. I know PVC has some give but could it be normal wear and tear?
- If it's an installer problem, should I expect him to offer to fix it no charge? Or reasonably speaking, how would you pros handle? The whole assembly is 140 bucks and not sure if you can get just the drain (or disassemble the cable, though I assume there must be some way)
- This plumber is a good guy, but if things go south, any ideas for how else I could fix it? Everything I've seen (sealer, suck in glue w/ vacuum, clip-on flange) seem like trickery or cheapo quick fixes... but maybe there are some legit leak stoppers out there.
Thank you for any advice!
