Nibco vs Watts 1/2" ball valve question (copper / sweat)
150
WI
See images. Installing on 1/2" copper that leads outside to hose, and one to the dishwasher. Home currently has old gate valves I am replacing.
The Nibco valve is 2x the size and 2x the weight of the Watts valve. I get they could be slightly different materials (?) but the size and weight difference is very noticeable. Each is lead free (LF). The Watts has "LF" on the body where the Nibco does not - its tag states lead free but nowhere on the unit does it say "LF".
I had planned on the Nibco, but saw the Watts at the local hardware and as they are smaller/lighter wondered if they might possibly be a better choice for this specific application?
Any input on which I should install?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Both 'good' mfrs. When I was soldering (mostly ProPress now), I liked the distinctively more exposed solder cup as the Nibco has.
  • Like
Reactions: 150
150
WI
I went with the beefy Nibco. The Watts heated up way to easily and the flux was boiling on each side of the valve at the same time so I pulled it. Made me wonder what it was made out of. Nibco unit did not do that.
Zayd
Michigan
I'm reviving this thread as I was at Menards looking to buy several 1" and 3/4" full port ball valves to redo my water setup. While the Nibco was much heavier, the Watts had a more refined casting and the ball machining was also cleaner. The Nibco had an awkward and bumpy opening inside the ball, while the Watts had a clean, straight bore that matched the rest of the valve body. The Watts was made in Mexico, while the Nibco had no indication of place of manufacture anywhere. I was leaning towards the Watts but ultimately left without purchasing.
Asking the folks at Supplyhouse, they say only their Webstone full-port ball valves (a brand made by Nibco) are USA-made. It really shouldn't be this hard to find a quality, USA-made valve.
Fitter30
Peace valley missouri
NF is a certification used in Europe. Valves purchased from plumbing supply houses are still a higher quality. Might have a 600 lb rating.
There are two types of plumbing supply houses one is mainly plumbers the other for pipefitters. They both overlap but if there is is one mainly for fitters they will have piping supplies for process piping.
Id use nibco or watts in a heartbeat on a cracker box taj mahal is another story . just kidding but on resedential construction Ill use nibco, watts , proflow from ferguson Im not real picky you can probebly pay double or triple at the most for higher quality 30 bucks maybe for 3/4 instead of around 10 bucks
John Gayewski
Iowa
The bigger heavier ones are bronze vs the lighter brass. Bronze is better, but not by much.
Zayd
Michigan
I did not catch that distinction, John -- good point. The Nibco is indeed bronze vs. Watts brass. I wonder if that also accounts for the rougher casting.
