New Reliance NG Water Heater Not Working
Eweneek1
Purchased a Reliance water heater model 6-40-NOCT 400 on 9/13/22. Installed without any problems in a rental unit for a single mom. However, the heater does not work. Problem is the pilot light will light and stay lit, but the gas valve status light never blinks no matter how long you hold the pilot on. Called Reliance and they said to use the reset button which I tried. The button does not work. Called Reliance again and they said it must be the gas valve. They sent a new valve and I installed yesterday. Still have the same problem. Reliance is located in Tennessee and not open on weekends.
WorthFlorida
Solutions
Orlando, Florida
Without any LED flashing it indicates that there is no pilot light, yet the pilot remains on. Moving the temp to hot it is assumed the pilot remains on. Is that correct? If yes seems to indicate that the thermocouple is working. However? Do you have a propane torch to place the flame on the thermopile tube? Do check that the pilot flame does make good contact with the thermopile.
However, I'm suspecting the thermal relay is bad or open. Do check the wiring to it. Will need a volt-ohm meter. There are several video's on how to check this switch.
Eweneek1
The pilot lights immediately and will stay on as long as I depress the pilot button. Have kept the pilot on for five minutes while depressing, but as soon as released the pilot goes out. So, no way to move to any other setting. Reliance is now sending the complete burner unit which includes the thermopile and thermal cut-off switch. Will test the thermopile with a volt-ohm meter prior to doing the replacement with the new thermopile.
