Work4latte
Hi, first time person here. I've been reading lots of information, and a lot of it is very helpful. My well has been slowly losing output over the past 10 years or so. Originally, I think it pulled about 8gpm, which is really great for my area. As of last summer, i think it will pull maybe 1gpm, and that doesn't seem to be constant. I had a well guy come out and check the pump, and replace it - no improvement.
So, i'm working on putting in a 1500g storage tank. The advice here on how the water will be pumped from the tank into the house is very good, and i think i understand what will be needed for that (csv and a jet pump, with a very small tank, right?)
The part i haven't figured out is how we're going to get the water into the tank, and if our filters need to go before the tank or after.
First, the filters: Kinetico water softener is currently being used to remove a lot of iron in the water. There's enough iron that it plugs up the head every 3-4 years and i have to get it rebuilt. I think i want to add an air-oxidizer iron filter before the water softener to see if that makes it easier.
If i put the filters before the storage tank, the tank will stay nice and clean and i won't have to get the iron sediment out of the bottom every few years (major plus for me) but i have to be sure that the pre-storage environment supports the filters - especially that there is enough water available for their backflush cycles.
After the storage tank the backflush issue is replaced with just cleaning that tank every few years, and the work of replumbing, which shouldn't be too bad.
Either way with the filters, the tank will need to have not more than 1/2 gal / minute flow to fill it. More than that doesn't guarantee that the pump won't try to go when there's no water - which pops the circuit breaker (currently happens whenever we try to do two things - run the dishwasher & flush the toilet, for example)
So, the question is, what sort of setup would be best for filling that tank? What should i be considering about filters before/after the tank?
and of course, being a novice, am i just barking up the wrong tree completely?
