hhcibtpaun
Hey Everyone,
So, I am getting ready to pour the concrete to seal up my floor (in the basement). Before doing that I just wondered what the junction of the drain and the ejector pit should look like.
What I did is this. The pit (it is a structural foam one) has a 4" hole in the side. It came with a rubber bushing. I am using a 3" drain pipe, so I bought a bushing to bump the end of the pipe up to 4". I installed the bushing to the pit dry, then used some plumbers grease on the inside, so I could slide the bushed end of my pipe in. Since the pipe has some pitch to it, it goes in crooked but it goes completely through. The bottom of the hole is about 16" from the bottom of the pit.
I plan on user a Zoeller 267 pump, which turns on at 12" and shuts off at 4". I am assuming everything I have done is OK? Do I need to protect any of the seals from the concrete or stone? Any other sealing required?
I just wanted a final sanity check before the concrete flows.
Here are some pics:
Comments are greatly appreciated.
Thanks...Mike
Here are some pics:
Thanks...Mike
