Tub overflow screws rusted
Alexbacon
Florida
Hi!
I recently purchased a house built in 1950. I know nothing about plumbing but after watching some videos I decided I wanted to update the fixtures in the tub. When I unscrewed the screws on the overflow cover, the screw heads were so rusted they broke off. The gasket looks pretty chewed up too. I don't know how to get the old screws out or how to attach a new overflow cover. Even if I get the screws out I'm not sure new ones would even screw into this rusted disaster. Is there anything I can use to just stick a new cover on? Caulk? Plumber style super glue? I totally regret starting this project and would really appreciate some help.
Thank you!
Do you have access to the wall behind? If so, the top part of the drain assembly can be removed and replaced. It fits together with standard 1-1/2" slip joint nuts and washers.
index.php
Hardware stores would carry the waste and overflow in brass, and you could install the top part into the rest of your existing drain.
Alexbacon
Florida
index.php
I do not have access to behind only through this little overflow hole. I'm not a bath person so I'm okay if it's not functional, I just want to cover this huge hole up now lol
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Drill out the old screws and tap new threads. Then use brass screws to prevent a repeat. Has the bracket that sat behind the cover rusted away or is it salvageable?
