Jasperjake
Hi All,
I purchased a Toto Drake Model number, CST776CSFG#01, from an online delaer, plumbing online.ca. I ordered the 1.6 GPF because I have had problems with low flush toilets in the past. After setting the toilet I noticed it rocked despite the tiled floor being flat. I pulled the toilet and checked the bottom with a straight edge. There are what appear to be stiffening webs that into the bottom of the bowl and one of these webs was "high". I can grind this high spot down and I suspect this will fix the rock, but is this somewhat common on these toilets? I might expect this on cheaper toilets but not on a somewhat expensive Toto. Additionaly, I am wondering about the model number, Since I ordered the the 1.6GPF model, I was surprised to see the bottom of the bowl marked C776CEF, and not C776CSF. Are all the bowls essentially the same. The tank is indeed marked as 1.6GPF. I don't mean to obsess about the toilet, but after finding I had to pull it and now grind it down, I am perhaps a little sceptical that I got sent a return.
