I am finishing our basement. My tile guy finished laying tile yesterday and is coming back today to grout. When I looked, I noticed he had tile just over the edge of the 3" drain pipe which won't work with a hub flange. I measured around the pipe to see how much tile he was going to have to cut out and just noticed the hole in the slab is 6" which is the same as the bolt diameter of the flange. The slab was poured with a plastic tube which had foam inside it to allow some wiggle room with the drain. So now I have two problems. The overlapping tile can be cut away but unless I get in there and try to tear out the vinyl tube and foam, even filling the tube with concrete won't be secure since the bolt holes would be right on the plastic. Any suggestions on how to fix this with the least amount of tile tear out?
As always, thanks for the great help here on Terry's forum.
