Test Plug for DWV PVC Hub
Dohc
Wisconsin
I can find many different types of test plugs for DWV PVC pipe, but I am not able to locate a plug for the hub part of a PVC pipe fitting. Do they make such a thing? The plug would have to be about 2.375 inch diameter (outside diameter of a PVC 2" trade size pipe) to fit inside the PVC fitting's hub.
Sioux Chief has a Test Titan I have used before but it fit somewhat lose in the hub of a PVC fitting...
882-series---mechanical-test-plug---testtitan.pdf (siouxchief.com)
wwhitney
Berkeley, CA
Yep. Used to use these when I didn't want to glue in a stub out in order to use an insert trap adapter.
Nice. Is the OD on the yellow plastic part the same or less than the OD of a hub? If so, that would be nice for leaving in while drywall goes up.
Cheers, Wayne
Tuttles Revenge
Cheers, Wayne
I believe the disk is the same or close enough diameter as the hub so that it can never fall into the hub. Its from my past commercial work when plumbing for wall hung sinks which had the least amount of room between the wall and the tailpiece and ram bits weren't a thing.
