Side Discharge Shower Drain
Allen Brown
California
I'm having trouble locating any information related to code on side discharge shower drains such as:
Infinity Drain:
http://focalpointhardware.com/infinity-drain-clamp-down-series-cdiq-42-drain-p-10756.html)
or QuickDrain USA:
or EasyDrain
I'm located in California.
I'm moving a shower and opted to not cut concrete and cast iron piping, so i used a Ferno nohub coupling a 90 street elbow (https://www.homedepot.com/p/2-in-ABS-DWV-90-Degree-Spigot-x-Hub-Elbow-C58072HD2/100342577) to get over to the new shower drain 24" away from the original. To give myself a 1/4" per linear foot grade and keep the pipe low i did chip away a little bit (less than 1") of the concrete between the two locations.
A few questions:
1. Is 24" of slightly graded, horizontal run between the shower drain and the drop to the p-trap acceptable? Is there a maximum distance allowed by code?
2. The selection of side-discharge shower outlet drains is limited. They look basically like flat 90 degree turns though. I assume the answer is no, but would I be allowed to put a 90 vent elbow below my new drain so I can use a standard straight down low profile shower drain? The 90 degree vent ABS would be directly beneath the drain, then a 24" sloped run to a regular 90, which drops down to the original p-trap and vent.
Jadziedzic
Active Member
New Hampshire
Consider that the entire length of that horizontal pipe will likely build up soap scum and organic materials over time, and will start to stink. (Even a short length of vertical shower drain pipe leading to the P-trap can show a similar build-up.) How will you manage to clean that horizontal pipe when that happens?
Tuttles Revenge
I'm guessing that its already installed.. How did it do? I've installed similar setups on occasion when a structural condition prevented a trap directly under the tailpiece and have never heard any negative feedback.
