I am remodeling my shower on our second floor in our 34 year old home. The present shower is tile with a fiberglass base that is centered. I would like to replace it with a 3 piece fiberglass unit(including receptor). My question or concerns are with the removal of the base from the drain. When I remove the strainer from the drain, I notice that there is lead sealing the outside lip of the drain. Did they also use the lead to seal the brass ring that sits on top of the shower base unit? It doesn't appear that the ring will unscrew. How do I remove the ring that seals the base and then what type new drain should I use to adapt to the current plumbing?
The drain appears to be cast iron, or perhaps iron pipe. I know that my father in his plumbing days used lead with cast iron pipe. I don't want to start pounding on things so I don't make matters worse. Techman
