pipe water main
joejoe2100
california
Hello everyone! I have no professional plumbing experience, I'm just a diy kinda guy. the white pipes/ tubes are for a sprinkler system. The valve there that is taped off with black tape was used to turn on the sprinklers to water the front lawn. The lawn has been removed and the sprinkler system is no longer used. I was thinking of removing the white pipe/tubes by first blocking the water flowing to them and then getting rid of them or maybe adding a taller outdoor faucet.
Last night I dug in there to see what I would be working with. I'm a bit surprised to see nothing but plastic tubing. In the dug hole the 2nd plastic pipe from the left has a plastic pipe coming from the street side which I am guessing is the water main? I am surprised by this because I though it would be metal. it flows up to the sprinkler system valve and to the metal pipe which goes into the house because when the red valve near the blue hose gets turned off water inside the house stops flowing. Im positive thats the water main, just surprised it is plastic and not metal.
Is it posible to replace that section of white plastic pipe that has the sprinkler valve with a metal piece. It has some kind of blue glue or leakproof liquid where it screws.. so it might not be able to be unscrewed??I dont know. Not sure if it's even possible because water would be flowing out if I unscrewed or cut it to replace with metal. Would be easier to put some protection around the white pipe that sticks out some 5 inches above the ground.
Any advice would be appreciated.
Thank you
yes the valve above the ground turns off water going ino the house, the white plastic is usually called pvc about 99 percent of sprinkler pipe in last 50 years is white PVC in our state . And as far as I know the water mains to the houses are still run inPVC on many if not most new homes . PVC is especially easy to install for a DIY but Us in the trade have all used it in California. I doubt you would be able to solder copper So Id say allow several hours for glue to dry and get all water out of pipes.
Id say look at some you tube or go to a home center , I and others dont mind and actually want to help , but you need to learn a little and by the way there is blue stuff called PVC glue? there is blue thread tape ? and blue pipe dope ? so there is a lot to learn Dont expect you to know it all and pipe can even be cut with a hack saw so not a lot of tools or knowledge required
joejoe2100
california
no problem. guess youtube and looking up already answered forum questions it is. that you for thr reply good sir
dont mean to turn you away but its a lot to go over every single thing . like telling someone how to frame a house and they dont know what a nail is . Ill give you some tips though pvc glue and primer needs to be used and directions on can primer first then glue
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I can not recommend working even on PVC unless you learn every step of assembling a joint. Practice but know, there is a good deal of detail to do a good joint. Also, old PVC can be brittle.
In a dark crawlspace is not the place to learn.
