Mixet volume knob turns temperature knob
Fil
Arizona
I replaced the mixet cartridge in my shower in my house that was built in mid to late 1980s. However when I turn the outer volume knob either clockwise or counterclockwise to turn on the water, or to shut it off, it grabs the temperature knob at the same time and spins it. So the only way to really turn the water on and off is to hold the temperature knob with one hand while I’m turning the volume knob. What am I doing wrong?
Dang Ive worked quite a few of mixets I cant remember the tricks . i know there are 2 diferant cartridges a long and a short . I also know I had this problem the handels rubbing each other I think cant remember the fix
ok disregard the above I was racking my brain and you tubed it a bunch of worth less videos but one good one try this its guatranteed because I too had the issue You tube " how to installa Mixet valve properly" its by monsterelkguy guaranteed its your problem this will keep your handles from binding up against each other !!!
  • Like
Reactions: Fil
what a coincedence hadent messed with mixet for a year or more and a guy called me to service 2 around 10 am today foillowed that video i referanced you and no problems !
  • Like
Reactions: Fil
Fil
Arizona
I did watch his video before and I think I tried that with the last cartridge and it didn’t work. I guess it’s worth trying again. On the previous cartridge, also, the plastic got chewed up where the back end of the cartridge has the other piece of plastic that goes into it. Where it enters the channel or Hollow area of plastic is where it got chewed up.
your complaint is that when turning off or on the water is it turns the temp control lever. it sure sounds like you have too many threads sticking out when you screw the end on which causes the 2 handles to jam against each other . I did 2 of them friday with no issue . plastic chewed up ? not sure why that happened
GReynolds929
Active Member
WA
Make sure you have the right cartridge. There are 2 different ones depending on the year of manufacture.
