Ethereal
I have a Toto toilet with the GMax fill valve and recently it's kept running after flushing, ever so slightly. After replacing the cap and inspecting it while filling I've found the following:
- When filling, water streaming from the top hole in the cap is trickling into the float reservoir
- Once the water level is up to the bottom of the reservoir, the trickling water starts filling it
- The float turns off the fill valve (mostly) before the tank water level reaches the holes in the sides of the reservoir
- If I close the shutoff valve most of the way to reduce the pressure, the problem goes away but the toilet fills slowly
Is this a design issue? I don't see any way this would *not* happen given the construction of the fill valve. Oddly it doesn't happen on another toilet that I have with the same fill valve!
I did fully disassemble and clean the fill valve just for completeness.
