Help With Double Vanity
okiee82
Minnesota
First off thanks in advance to anyone willing to help me out. I would much rather take the time to do it right then just making it work. I have browsed the forums and looked at many pictures I think what I have will work I just would like to make sure.
I have a double vanity that has two sinks and drawers in the middle. I would like to do what I have badly drawn in the picture and based on the pictures I have seen posted should work but I could be totally wrong.. The sinks would be higher based on where the original waste line is but the new vanity sits higher as it is..
The picture is just an example the pipe would actually be over a few feet to left but for picture purposes I drew it like this.
Thanks Again for any help...
You can't run a double fixture fitting or a cross with 1.5" pipe.
It needs something different.
This wouldn't be code with 1.5" but it works.
Normally you have 2" for two lavs with 1.5" trap arms.
This one has 2" on the down side.
okiee82
Minnesota
So if i switch out to all two 2 inch with the trap arms being 1.5 would my drawing then work. I would think it would match the picture above then.
Thanks again for the reply!
