Rsaybe
I like to make sure I'm installing these drain lines correctly. I'm including a rough photo basically showing how I planned to put this all together.
Does this look correct? I'm using 2" DSW drain pipes. Studs are a bit on the tight side at 14" so I laid this out while allowing me to have the p-trap within the stud. The washing machine stand pipe is 18" long.
The vent is off to the left about 20" away from the p-trap as noted in the photo.
I noted what each drain is being used for in the photo.
The small white box on the right stud is a gas outlet dryer box.
Does this all look acceptable?
