Ben Y
I've seen similar questions asked, but there seem to be enough variables that I'd like to ask here to be sure. See attached photos. I have a basement bath roughed in, it is wet vented. The vanity is the most downstream fixture. On the other side of the bathroom wall, I'd like to put a bar sink, and I'd like to run the drain line through the wall, through the bath vanity cabinet, and tie it into the vanity drain line.
Is this permitted? If so, is there a maximum distance between the two sinks and/or a minimum height for the bar sink above the bathroom sink? Do I have to vent the bar sink separately, and if so, can I use a studor vent? I am in Indiana.
I don't want to do this badly enough to dig into the concrete floor to access the drain line, so if there is no good solution, I'd rather just forget about it. However, if there IS a good solution, now is the time to do it.
Thanks in advance for any advice.
