tropostudio
Maybe this should go in the water heater forum, but I think its pretty 'boiler system' related:
I'm finishing my Westinghouse WBRU80 (low/med head firetube boiler) install. This is a direct-pumped system. My Caleffi Aircal separator is just downstream of the boiler CH supply and upstream of the single CH circulation pump. My expansion tank and make-up water system are just upstream of the boiler CH return at the boiler. Thinking is: 1) am pumping away from the point of no pressure change, 2) have air separation in an area of minimum solubility, and 3) am keeping the expansion tank on the cool side with minimal pressure changes on the diaphragm.
The Westinghouse install manual shows the Indirect DHW tank loop plumbed into the lower boiler supply and return ports, and the DHW circulation pump between the DHW return and boiler return. This means the Aircal separator is not working when the DHW loop is running - which I prseume means all summer when there is no call for CH.
Question 1: Wouldn't it make better sense to tap into the CH loop for DHW directly downstream from the Aircal, so that the DHW circulation pump is directly parallel with the CH circulation pump? This way the Aircal is always active.
Question 2: I am installing a spring check valve on the CH return directly upstream of the expansion tank/make-up water per the install guide. Should I also have a spring check valve on the DHW return between the indirect DWH tank and boiler? Would this help isolate heat flow between the DHW and CH loops?
Thanks, Chris Krumm
Thanks, Chris Krumm
