Serkan
I am not a plumber and doing some reno on my house as a home owner.
I always see diagrams using Wye+45 when changing draining direction.
I have a 2” drain coming inside the joist bay (parallel to joists), this 2” run needs to drop into 3” drain that runs in a soffit (right angle to the joists)
Can i use the Wye+Long sweep 90 to make the transition. Or do i must to use the Wye+str45+90?
I think the long sweep makes a nice transition for water to flow in right direction.
Just need to make sure Wye+long sweep is ok and i will glue them together.
