I think it looks to me like someone jammed an ABS cleanout tee into a random schedule 35 sewer pipe that may not even be hooked up to the sanitary sewer. Unless that is a sleeve. Can you open the plug and use a flashlight and mirror to see down the line. If its black pipe you might be OK-ish.. if its white.. youre hosed.
.View attachment 83575
Behind? I was thinking this was a horizontal pipe, but I did not know the direction of flow.Bathroom remodel just done upstairs. New toilet was just installed by a local plumber. However, right after we noticed the water coming up from under the laminate flooring in the basement bathroom which is right behind this pipe. The leak seems to be where the pipe goes into the floor.
yes! I dont think it is the clean out plug though. Seems to be a bit lower. The only time it leaks is if we flush upstairs. It's a brand new toilet above this pipe. We are turning the HUGE master bath upstairs into a powder room and a seperate primary bathroom. The toilet above this BEFORE was removed and the new toilet was shifted over a few feet and installed two weeks by a professional plumber here in town. The picture is where the clean out was hidden behind sheetrock in the downstairs hallway. The room right behind this is the full downstairs kids bath where we first noticed the water coming up from under the vinyl plank flooring right behind where the pipe is. The carpet right in front of the pipe in the picture was getting pretty wet as well.is it possible your c/o plug is leaking? when you flush repeatedly do you get leakage?
The pipe is vertical in the hallway wall in basement right below where new toilet was just installed upstairs. We tore out the sheetrock when we noticed the carpet in the picture, right in front of the pipe, was getting wet. Who the heck sheet rocks over a cleanout pipe? Right next to this is the doorway at the end of the hall for the kids bathroom downstairs. The water was coming up in the cracks of the laminate flooring in the bathroom right behind the pipe. Here is a better pic. Nothing in the bathroom behind leaks. Just the flushing of the new toilet upstairs, above this.Behind? I was thinking this was a horizontal pipe, but I did not know the direction of flow. Is this a photo looking up or looking down? Which way is the toilet waste coming from?
It rums vertical in the basement hallway under the new bathroom upstairs. Only flushing the new toilet causes the problem. SMDH.Behind? I was thinking this was a horizontal pipe, but I did not know the direction of flow. Is this a photo looking up or looking down? Which way is the toilet waste coming from?
no doesnt seem to be loose. No smell at all. There were a couple seems in the abs pipe that leaked a tiny bit from being jiggled around when the pipe was sawed above in the ceiling where the new run was put in for the new toilet. I think the silicone gave a little. So I replaced that with the white pvc. No leaks there now. Just under the clean out plug. Ugh. Gotta figure out what to tear out next I guess.I am not a pro.
Is the ABS pipe just hanging loose in the PCV pipe? If so, that is certainly not right and could leak. It could also let sewer gasses escape into your dwelling. Is there a smell?
If it leaks up through the sleeve when the toilet upstairs is flushed, the easy answer is to not ever flush the toilet.. solved.The white pipe seems to be just a sleeve and the black pipe pvc scd 40 3" continues through it.
