Clifford82
Interesting situation, not sure if it's coincidence or a fault of the setup, but one of my tankless water heaters quit working after I installed a mixing valve downstream.
THE SETUP: I have two Rheem 15a621 in series (yes, I know these are too small, it's a 1966 cabin and they were there when I bought it). They were both working fine, and then my inspector wanted me to install a mixing valve when I remodeled the bathroom in order to bring everything up to code. A few days after the valve install the second water heater stopped working. I installed this valve (https://www.cashacme.com/product/hg110-d/). So the setup goes:
COLD IN ----- RHEEM1 ------- RHEEM2 -------- VALVE -------MIXED OUT
THE SYMPTOMS: The second water heater has power, but it will usually not switch out of standby even when there's flow. If it happens to switch on it will then usually not switch off when the water turns off. So it seems to have trouble detecting changes in flow (resistant to turning on when there's flow, resistant to turn off when there's not). If it's stuck in the on position it will stay that way until it overheats and trips the circuit.
QUESTION #1: Does the presence of the mixing valve somehow cause the second water heater to misbehave, or is this coincidental? The valve seems to be working fine and there's normal water pressure coming out of it, so I don't think there's a backflow issue but who knows.
QUESTION#2: Any idea how to diagnose a flow sensor issue on this model (assuming that's what this is)? All the troubleshooting info I can find is for newer models with digital displays, this just has a knob and LEDs.
QUESTION#3: Assuming I can get the second water heater working again, would it make more sense to redo this circuit to have these two heaters in parallel instead of in series? I've been just using the one heater and it's providing sufficient temperature increase, so in theory the two in parallel should increase flow at that temperature increase, right?
Any help is appreciated, thanks!
