Securing vintage sink to the pedestal
AdrienneF
New Jersey
I just got a 1930s Standard Sanitary Mfg Co pedestal sink. It is just the sink and the pedestal and I am wondering how to secure the two parts together. It looks like there is a place on either end for a long bolt or screw assembly. I'm not sure what would hold onto those prongs on the bottom of the sink. Has someone found a way to safely secure the sink and pedestal together? What sort of bolt or screw should I use? Maybe someone has some photos of what the original bolts looked like? Any help is appreciated. Thanks!!
It would have to be assembled before installing it. A "U" channel under the bottom lugs with a hole in the center. A threaded rod with a nut inside the socket on the sink. Tighten the bottom nut to pull the sink tight to the pedestal, then set it in place. You cannot use the bottom "U" socket because the rod would interfere with the drain.
AdrienneF
New Jersey
That is very helpful, thank you!!
Montreal, Canada
You're missing some parts, like hangers, and threaded rods that pull two things together. Some car exhaust is secured this way to the chassis.
You're going to have to hit up some old timer that can rememeber how these were like.
Please update your thread with new pics of your progress and discoveries. This sink is fantastic, I love restoring stuff like this!
Sjsmithjr
Knoxville, Tennessee
The old timer WAS the first to reply. HIS description of how it goes together was easy to understand.
Judicious use of CAPS in honor of HJ. I've learned a lot from him and I'm always impressed by his knowledge base.
