Livin4Real
jbfan74 said:The ears have a purpose!
They pull the device tight against the drywall so the cover will sit flush and you are not using the cover to hold the switch flush.
And if you snap off the ears the switch will tighten up against the gang box. This is helpful for people who can't leave the power off very long on an extended remodel (like mine), allow you to drywall it without having to pull all the switches back out until inspection. I just used a scrap piece of drywall when setting the depth of the box. The switch is just as tight, if not tighter being flush with the gang box.
