PVC roof power vent options
Vietjdmboi
Anaheim
I am planning to install a navien npe-180a2 but wanted to see what options I have for the pvc vent. Plan is to do a power vent. Intake air will drawn in from the garage and vented going straight up out the roof.
Currently there is a 4” asbestos flue which I want to remove. The roof flashing is for a 4” diameter pipe obviously. I found a 3” direct vent with a 4” diameter body but don’t need the intake side. Is there any other options or would using the 3” concentric vent be my best option?
thanks!
Fitter30
Peace valley missouri
You don't need a concentrate roof vent your not running combustion air. If the asbestos flue is straight can run 2" pvc up to 75'. A 90° ell = 8' you will use 2- 90°
on the roof flash around the 2" to cover the.asbestos pipe.
Vietjdmboi
Anaheim
Here is an image from the roof side. Flue is about 3 ft long and straight.
Fitter30
I'm surprised you didn't have draft problems as low as the flue is from height of the peak with a natural draft water heater or furnace.
Vietjdmboi
Anaheim
"Why not replace the existing flashing with a new 2" flashing?"
Im not against this. Just wanted to see what options were available with the current flashing
