Odd size steel pipe nipples
ej
California
Hello-
I'm putting in a tub faucet and need a 3 1/4" nipple in order to have <1/8" gap to caulk. Using the standard 3 1/2" that I can get at home depot, I end up with a 3/8 gap which seems a bit much, and 3" is too short.
The Home depot guy said to mate up smalller nipples with a coupling; is that the typical solution for pro's? I'm nervous enough about having two hidden joints in the wall that could leak, much less four. It also seems like it'll also get squirrely trying to get the faucet to end up in the down facing position when they're all tightened up.
How do you folks do it, or am I making too much of this?
thanks-
Ed
LonnythePlumber
Plumber, Contractor, Attorney
Wichita, Kansas
Slip Spout
You are correct in wanting to get a good seal at the spout to wall connection. You could install a piece of copper and use a slip on spout. Or you could get a spout that has it's pipe connection at the nose (outlet) instead of at the wall. I have used the coupling approach.
ej
California
Thanks, Lonnie. The spout is part of the fixture package, and the wife really likes it, so changing the spout is out.
You mentioned copper which got me thinking.... Can I just make it out of copper and sweat two threaded ends to the correct length of tubing? or do I risk damage when trying to tighten it up? That could make it very easy come to think of it.
-Ed
Jimbo
San Diego, CA
1. You can make up a nipple from a piece of copper and two male adapters; it is simewhat fragile. Especially when you need to remove it, the copper might twist.
2. A big plumbing supply house may stock nipples in 1/4" increments; also the supply house or a large contractor probably has a nipple attachment for their threading machine and can make any length.
