Need help w repipe. Moving toilet location/wet vent question
Ncplumber2024
North carolina
Hopefully my drawing explains it enough. Looking to move toilet to new location as drawn on right. Wasnt sure if i could 90 a toilet fixture drain straight down into that wet vent/common vent serving lav and shower. I know code said toilet should connect at bottom for vertical wet venting. So if what i drew wont work, could i hit my closet bend. Then 45 down on toilet fixture
Drain 45 back horizontal and dump into san tee at bottom of stack before itnturns horizontal? What are my options? Thanks in advance as Im a newer plumber. In nc.
Ncplumber2024
North carolina
LINK TO MY DRAWING
foplumbing
Florida
shower and w/c need to tie in exactly at same elevation at the stack... there is a fitting for this
the lavs need to wet vent from above... can't tie in exactly at same spot as the other two
