ELECTRICAL QUESTION
Michael Young
North Carolina
wwhitney
Berkeley, CA
You seem to be confusing Watts, a unit of power (energy/time) with Watt-Hr, a unit of energy (literally 1 Watt for 1 Hr).
So 1000W is exactly that. If it runs at nameplate rating for 1 Hr, it will generate 1000 Watt-Hrs, i.e. 1 kWh.
Making use of such a generator is tricky. The power straight out of the generator may not be very smooth, or it may not be 60 Hz (if it's a simple generator where the output frequency varies with the rotor speed). So it may need to go through a rectifier/inverter. Then if it's a standalone system, you'd need storage (batteries) and a mechanism to instantaneously balance supply and demand. If it's grid-tied, you'd need a grid-tie inverter and the usual permission from the power company, just like a solar installation.
Cheers, Wayne
Michael Young
North Carolina
Cheers, Wayne
so if a 1000w generator runs for 1 hour, it will produce 1kwh
so 24kwh hour per day
8760kwh per year
and the power company will credit me .13 per kilowatt hour
so the little hydro-generator in the creek would potentially generate $1138 per year
so I would be better off installing a 5kw hydro generator with a grid-tie inverter
