Drain for freestanding tub
Tuttles Revenge
What you're suggesting, building an overflow using a WYE fitting after the tub shoe, in your hand, is exactly how I built mine when I had to move my tub over and still have the drain hit the trap. I found a photo of the tub that I had to build the same thing since they moved the tub after it was originally installed and I broke the waste and overflow that came with the tub.
I've seen some absolutely terrible drains from the factory, so you're likely to do much better.
I like that method basicaly to attack this challenge,
Dogwell
Arizona
Thank you for that photo! Do you think this would work on a cement slab (post tension so we cannot break it without expensive xray)? The plumber says it's impossible to install a freestanding tub on slab without an island drain. While I understand it may be difficult, I was hoping there may be some tricks to get it done.
Tuttles Revenge
I can't think of any reason it wouldn't work. You're just offsetting the tailpiece of the tub over to the vented trap. The type of floor doesn't matter except for making a case to an inspector about the amount of work it would take to do it differently.
is the p trap underneath the tub? If yes its all good . if no and its 3 feet away out in the middle of the room then of cource it wont work it will be exposed .
3BoysMomma
Hi All. We are remodeling and are not sure on the options for this tub drain. We have post tension slab so breaking the concrete is not really an option this drain is about 2 ft from the wall making the tub stick out quite a bit. I've seen a lot of freestanding tubs come with flexible hose drains, but I imagine those accordion style folds would easily clog / smell / do all sorts of things down the line. Is there any other option to move this drain? Do angled pipes exist? Is there a limit to the how far the horizontal pipe can extend if we try to push the black pipe / white elbow to the center? Any help would be most appreciated.
3BoysMomma
I’m replacing an old garden tub with a clawfoot slipper tub going from a center drain to end drain and exposed overflow/drain plumbing vs all hidden plumbing for garden tub it’s a lot of parts & $$ additional I didn’t anticipate.. I’m going with wall mounted fixtures, moen has a couple and wayfair also most are floor mount or antique look and that’s not my style or the tub style. So good luck!!
