uscpsycho
I have a shower that is operated by a network controller. The way my contractor set it up, the controller will be close to the valve. Is it OK for cat6 cable to be in contact with a hot water pipe? It would not run parallel to the pipe, it would perpendicularly cross it, so just one point of contact.
If this isn't OK, is there any kind of insulation or barrier I can use to keep the cable from touching the hot water pipe?
For those who aren't familiar with it, cat6 is a low voltage wire like the cables you plug into your router. These aren't high voltage wires so I don't think fire is a risk but I want to be sure the heat won't damage or melt the network cable.
