Burcam Floumac Low Pressure Problem
mchernecki
Gull Lake, MB
I have a Burcam Floumac 3/4hp pump that is connected directly to 300 Gal caged tank. I use this to water the garden. This setup has been great, but this year there is no pressure, the water slowly pumps out. Is there anything I should look at replacing since parts are available?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
You might try cleaning the jet on it. I cannot tell from the IPL whether the drain plug aligns with the jet or not. On most jet pumps there is a pipe plug that you can remove and shove a wire in to clear the jet.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Those type controllers are a problem. They advertise no pressure tank or pressure switch, but a pressure tank and switch are two of the most important parts of a pump system.
What do you have to do to get the water pumping again after it stops?
