Big Blue Filter Housing / O Ring Blues!
Lee_Leses
Pennsylvania
So, not sure why this has been so difficult for me.
I had a 10 x 4.5 big blue filter housing installed about 2 years ago, when I had the GE softener installed.
This is only about the 3rd time I changed the filter.
I had to get a strap wrench because the housing would not loosen.
Then I took it apart twice, the 2nd time using a new or-100 o-ring.
I'm still getting a slow drip from the housing.
Especially the 2nd time I took it apart, I made sure to use plenty of food grade silicone lubricant.
Is it usually this hard to get a good seal?
Am I supposed to hand tighten it, or really apply pressure to the plastic tool?
I've been hand tightening it so far.
Is it better to use the flattened o-rings than the round ones?
Is there a better kind of filter housing to use?
Any experiences or thoughts greatly appreciated!
Thank You,
Lee
Lee_Leses
Pennsylvania
I'm also wondering if a flat/square o-ring might seal easier, if I could find them?
A spare housing I have seems to have shipped with a flatter o-ring than the ones I'm trying so far that are supposed to fit.
Maybe yours is not a real Pentek housing, but something else.
There is a wrench made for the purpose. It is normally recommended to only use that for loosening, and tighten by hand. Maybe the wrench could help. Pentek number is 144368 SW-4 Wrench for 20" Big Blue.
The real housing uses a round o-ring.
Something is damaged I think. Try another o-ring, and inspect the housing and sump top for damage. Sliding a fingernail over the surfaces that the o-ring touches may let you detect a flaw.
Pentek O-ring is part 151122. I think these are equivalent:
Ace Hardware 4001756 or Ace 49561, American Plumber W 10-OR and 152032. 151122, UPC 33663005082, Culligan OR-100.
Lee_Leses
Pennsylvania
The housing I'm attempting to use looks exactly like this, with a yellow sticker on it.
I'm thinking from some videos I just watched that it's not a Pentek.
So I'm thinking this shouldn't be this hard, right?
Will take it apart and inspect it again.
So a housing uses either a round or a square o-ring specifically, but not both for the same housing/unit interchangeably?
Lee_Leses
Pennsylvania
Wow! The way the o-ring's held in the Pentek sump is totally different! UGH
Will have to look at the cap I have more closely.
Lee_Leses
Pennsylvania
OK so here's a little update. Please don't laugh at me I'm doing the best I can with this, LOL! So from 10 PM to 6 AM this is all that it leaked, so I have some time to think about what I'm doing with it. I looked at a ton of pictures of these housings, and I'm amazed how they all look so similar and accept the 10 x 4 1/2 standard filters, but they have a LOT of different O-ring designs. Does anyone recognize this brand? I may need to dump this brand and get a genuine Pentek, The O-ring design on this is very different than the Pentek.
If it continues to leak at this very slow rate, I may wait until next weekend to take it apart again. When I take it apart again I’ll look very closely at the cap and everything. I didn’t over tighten it, just hand tight and then a little snugging with the plastic tool.
Martin Boring
Malcolm Ne.
Had a guy I had put a whole house filter in for a few years back called and said he had changed the filter and couldn't get the housing to quite leaking. Very small leak. He had provided the filter when I installed it. Long story short I found the box store he had bought the filter at had changed brands of filter housings and the O ring was different and wouldn't quiet seal on his housing. Make sure you have the correct brand of O ring for your housing and that you didn't crack the filter housing. I have the Omini brand on my house and like that housing design.
Lee_Leses
Pennsylvania
Thank you. I'm wondering if anyone can identify the brand I have from the pictures above.
I looked on the blue part for what brand it is and so far I didn't see anything useful printed on it!
Martin Boring
Malcolm Ne.
Lee if the top picture is the one you have it looks like a Omni brand B7 filter housing and the O ring kit should be a OK7. In my area Menards is a dealer for Omni in my area.
Do you still have the original o-ring? Measure that for thickness.
People have posted that the OR-100 is about 5.465 inches ID. Maybe you can compare to either the housing or the old o-ring and see what dimension should change.
The old O-ring typically will have stretched longer, and that is why you could not reuse that. Anyway, you may be able to order an o-ring from the many sizes available.
Lee_Leses
Pennsylvania
Thanks Reach! I like your thinking on this issue.
I think I'm going to explore different brands of O-Rings too.
It seems not all O-Rings are created equal! lol
Also going to switch to Pentek filters, the off brands suck!
