Best chemical/product/brand to descale limescale from hot water tank?
Imcool
Toronto
Hello members,
I am changing "SharkBite U3088FLEX18BVLF Flexible Water Heater Connectors" (waiting for shipment to arrive)
This hot water tank has not been drained /flushed in years so I am wondering if this is a good time to descale the lime deposit from the hot water tank.
I did some google research online and found following information,
1 Citric acid to clean limescale.
2 Vinegar to clean limescale.
3 amazon product based on citric acid to clean limescale.
I will go with citric acid to descale, looks like its a better and cost effective option.
if you know something better to be used for descaling, can you please advise?
This is model for my hot water tank I wish to descale
This is what I found about how much citric acid to use.
Regards
I used phosphoric acid. Mine was Kleen-Strip, sold for concrete etching. I am not saying it was ideal, but a lot of crud came out. I alternated. I also used laundry detergent.
I also used mechanical spraying. I have considered sticking an electric pressure washer wand into the anode hole or the drain hole. I don't know if the tips are narrow enough; they seem to have a wide nozzle on the current offerings. I collected water from my drain hole (having put a 3/4 NPT nipple in there to give a longer bigger passage) into a short plastic tub. I used a small utility pump to pump the water out of the tub, and removed sediment mostly settled into the tub. https://terrylove.com/forums/index.php?threads/draining-tank.62739/#post-465034
I sometimes recirculated the output of the utility tub back into the anode hole, and sometimes out a hose to the outdoors.
Imcool
Toronto
Regards
[/QUOTE]
will phosphoric acid not damage any other thing inside tank? what is the exact amount to use, and what strength? with how much water and for how long?
regards
