AS Whirlpool Tub Install?
valleyviewlawns
Helena, Montana
I recently bought a 5'x32" whirlpool tub, with a build date of 7/2000 for a remodel that we are doing. It looks unused but I have a problem with the install. The end with the drain is 2 1/4" taller than the other end. When it sits on the built in base it does not sit level. I do not think I can "hang" it from the edges as those are not for holding the weight of the tub. How do I make this sit level? I have never seen anything like this. This is an American Standard Model# 2770.018.020.
Thank you!
Normally a tub sets on a deck, or stringers on the wall and is supported from below. When installing they recommend shimming. Which really is an easy way of saying, not their problem.
The best way is to have a few piles of mortar mixed up wet, and then drop the tub down over them, which squishes the piles of mortar down and out, conforming to the bottom of the tub.
You don't need full contact, and so some points of contact will be enough for support.
valleyviewlawns
Helena, Montana
Thanks Terry. This tub has a built in base, and at the end with out the drain it has a platform for mounting the pump. It just seems weird that if I level the top then the base will have a difference of 2 1/4" from one end to the other. I am wondering if this was a special order tub.
