What's the secret to no leak the first time?
TSPORT
Philly,PA suburbs
Hi all. I have been doing my own plumbing repairs for decades but to this day I have not figured out a way to install a water supply line (generally 3/8ths chromed copper)with a brass compression sleeve that does not leak. Further tightening of the nut does not seem to help. Years ago I even snapped a line off due to overtightening. I usually end up having to take it all apart and making a new tube/sleeve assy. and trying again. Sometime I just wait until the fitting crusts up. Gotta be a better way.
I make sure there are no burrs on the tube. Should I be coating the sleeve & tube w/ joint compound before I install? What's the secret y'all? Thanks.........................TSPORT
TMB9862
I brush pipe dope over everything but it really is not necessary. Do you have the line as far into the valve as it can go? Do you have the line straight up (if it's angled inside the valve it will leak)? That's about all I can think of.
Furd
Engineer
Wet side of Washington State
Make sure the tubing is perfectly round and clean where the ferrule will seat.
Make sure the nut is clean inside and slip the nut onto the tubing.
Make sure both the internal and external portions of the ferrule are clean and not damaged, then slip it on the tubing.
Make sure the "socket" on the receiving fitting (shut-off valve) is clean and not damaged.
Bottom out the tube in the receiving fitting and while holding the tube bottomed tighten the nut hand tight. Continue holding the tube and tighten the nut one complete turn with a wrench then check for leaks. If it leaks, continue tightening to a maximum of one and one-half turns beyond hand tight.
Over tightening is as bad as under tightening.
Pipe dope or teflon tape is NOT necessary and more often than not will interfere with a good seal. At most you may want to use a tiny drop of light oil on the threaded portion to reduce friction.
Verdeboy
Why not use the flexible supply lines? Even a plumbing hack like myself has never had one leak.
TSPORT
Philly,PA suburbs
I don't like the flexible lines for toilets because they are visible. The chrome tube looks much neater & nicer. Also, it always seems whenever I try the flexible lines, the length is either just a bit too short or long to make a nice flowing bend or circle. I will give it a few more snugs w/ the wrench. If no good, looks like it's time for another compression sleeve & piece of tube. I will try bottoming out the tube in the valve next time. Don't think I've been doing that. Didn't think it mattered, thought the compression sleeve was doing the sealing. Appreciate the input!.................TSPORT
Furd
Engineer
The ferrule does do the sealing but you must have the proper length of tubing past the end of the ferrule for it (the ferrule) to properly crimp to the tubing.
SteveW
DIY Senior Member
Omaha, NE
I like Furd's suggestions.
Like he says, I've started using a drop of oil on the threads (something I learned on this site, from Terry) and it seems to help.
One other thing to add - try to make sure the tubing enters the fitting as centered as possible, and with (ideally) no lateral tension - I think it helps keep the ferrule properly aligned on the tubing, not cocked a little to one side. (Oops - I see Marlin already said this)
Dunbar Plumbing
www.KoldBreeze.com
This is a so 80's thread
Years ago this is what we always used. There wasn't anything other than pex risers and that was becoming common as time moved on.
I've never been able to bend a closet or faucet supply perfect enough to go in without having to do some major bending/prying of either the angle or straight stop to force it into position. More than likely this is where the distortion starts.
Also,
Those chrome copper risers always look horrible over time. Urine splatter will have those green and corroded in no time flat....along with the constant sweating of the supply line in those transition months.
Been using flex supply lines now for 10 years and have no intention of going back. If I base how many I've bought/used in those 10 years.....not one has blown.
I've had a couple/few leak......but that was either high pressure or the 400A had a sharp edge on the shank causing it to leak.
The only time I'll use chrome risers is for those extensions in rare cases. Most if not all chrome/copper risers have shown leaking at some point in time.
Master Plumber Mark
www.weilhammerplumbing.com
flexible lines are best
I had to go to the SS flexible lines back in
the early 90s because of the labor involved
trying to make the chrome ones lok good and the time it took to do this....
I actually had apprentices that could not make one
look good or spent the day trying to hook up a toilet
I have never had one burst......
and the customer could honestly care
less what they look like
and they look
great from my house......
Cwhyu2
Consultant
Cincinnati OH
I was trained to use c/p copper risers and after about 300 of them you get
feal on how to bend them to fit.Then Ibought a tubing bender.
Kordts
exurban Chicago
Check out the Brasscraft Innoflex. I actually came up with a similar idea, and posted about it, but didn't think anymore of it. I am glad to see someone was able to bring it to market.
GrumpyPlumber
Licensed Grump
Licensed Grump
I use chrome risers on Pedastils & toilets when the customer requests them, but advise them on the corrosive tendencies as someone stated above.
They almost always give me a hard time at the angle stop if I don't wrap the ferrule in teflon 3-4 times, then crank them on, just be sure NOT to over tighten.
That can break the compression nut, usually you want to see at least one thread left below the nut.
TSPORT
Philly,PA suburbs
Thanks everyone for all the useful info. Never could get the miniscule leak to stop this time so I just started over with a new piece of tube and ferrule, smeared the tube w/ some pipe dope before I put the ferrule on and then a little more over the top, put the nut on and gave it about one turn after finger tight and voila!, no leak. (I still like the chrome tube for short runs when visible. Since I am not doing this for a living, I can afford to spend the extra time screwing around).............................TSPORT:D
Frenchie
Jack of all trades
Grumpy, you surprise me. I'm no plumber, so I've only done maybe half-a-dozen; but they give me no trouble at all (knock on wood!). Guy who showed me, stressed that most people crank them too hard. Sounds like that might be you? I'm always surprised how little it takes.
My trick: finger tight + 1/4 turn, then open the valve just a little; wait for water to start dripping, tighten untill it stops + snug it a bit. Test under full flow.
No oil, no dope; perfect alignement's the crucial thing, I was told.
My problem is cutting the tubing to just the right length: I tend to be just a wee bit over, and how do you trim 1/8" without distorting the tube? So always get a spare one; and I usually end up using it.
TheZster
Fort Collins, Colorado
I believe Frenchie hit it on the head. Compression fittings are often overtightened to begin with, resulting in leakage. I always put a compression fitting together just a tad more than finger tight - turn on the water and slowly, slowly, tighten until the leaks disappear. Works every time for me.
Ian Gills
Senior Robin Hood Guy
USA
Yep, let it leak then tighten. I do this with all compression fittings now. And what a shame it's a brass craft gate valve. I would have had a ball valve on there whilst I was fitting the supply.
GrumpyPlumber
Licensed Grump
Licensed Grump
Frenchie, Chrome plated tubing with compression is the problem, not copper or poly.
One of the first things I was taught was to teflon the ferrule on compression that goes around chrome by an oldtimer.
Copper is never a problem.
Make note of it when you do a chrome riser, do it without teflon and watch.
GrumpyPlumber
Licensed Grump
Licensed Grump
Also, sizing/cutting the tubing is simple, loosely connect the top so the lower part swings with a small amount of push (on faucets make sure the tube doesn't angle into the top diagonally once shaped), hand tighten on toilets so it doesn't move back and forth but still rotates, bend as needed to locate it immediately next to the valve.
Mark with a fine sharpie about 1/4" below the port without the nut on it, remove it, then cut.
Put the bottom in first, there should be a slight bit of play up and down so you can move it into position to the top without bending it too much, loosely tighten the 3/8" nut, completely tighten the top nut with trusty basin wrench, then fully tighten the 3/8" at the bottom.
On a toilet it's obviously much easier to position with the flat seal on the toilet side as long as the 3/8" nut is semi loose, just make dam sure you tighten the toilet side first, that seal has to be tight and the 3/8" below should have some play.
OR, get flexible connecters for a few more bucks and don't horrify the customer with all the grunts n groans.
