Old ball valve, stem fused to packing nut?
Mikegmi2
Michigan
Hi all, so I have an old shutoff valve where I cannot for the life of me tighten the packing nut without shutting off the valve. I have a slow drip. The stem of the valve is stuck to the packing nut...so when I rotate either, they both rotate...so I cannot simply tighten the packing nut to stop the leak.
I have tried taking 2 pairs of channel locks and holding the stem firm, while trying to tighten the nut...will not budge. I have tried using some WD40, tapping all over the stem and nut to try to loosen them from one another and no luck.
It sucks because this is my main shutoff coming from my well, so it will be tough to replace if it comes to that.
Is it possible to buy a new valve, take the new packing nut/stem/handle, and replace the old stem/packing nut with new?
Or is there an easier way to stop this leak without having to cut out the old valve and replacing the whole thing?
Sylvan
Still learning
New York
Instead of channel locks try using a Crescent or a good fitting open end wrench and told hack as you try to turn the handle
Channel locks have a tendency of not holding tight enough and the mar the fitting
I suspect you don't have a ball valve.
If you open the valve all of the way, is the dripping a lot slower than if the valve is partly closed?
See https://terrylove.com/forums/index....acking-nut-on-main-shutoff.79208/#post-575204
Mikegmi2
Michigan
Here is a photo of the leaking valve with handle off, pretty sure it is standard ball valve. The handle is blue, says NIBCO, and below that says "mss" and then "SP-110".
Mikegmi2
Michigan
Based on the photo above, is there any trick to loosen the valve stem from the packing nut? Or a way to replace the stem/packing nut without cutting out the whole valve?
at a time when you dont mind turning water off. get more agressive hold nut and turn stem. but your probebly going to replace valve
