Is this a schrader valve?
Rbridges
Georgia
I figured it was a plain ole Schrader valve. The bottom was broken so I had nothing to compare, but I see that pressure pumps use Schrader and snifter valves that look similar. It’s the bottom valve with red arrow pointing to it. Thanks for the help.
Cliffyk
Saint Augstine, FL
A Schrader valve is a small air air valve, as commonly used on automotive tires. They are also used on "bladder" type water tanks to monitor and maintain their air charge. The valve you have indicated is almost certainly not a Schrader valve--got a better photo?
It would be a snifter valve, which is very much like a Schrader valve. However it has a very weak spring that will easily open if there is a vacuum. When you put a valve cap on for protection, you make sure it is not one with a seal. Tire valve caps seal, and in fact the cap seal is the main seal for your tires.
That snifter valve would be on the well side of of the check valve.
Typically there would be a drain valve (or a little hole) down the well a bit, and when the pump shuts off, the drain valve lets water out. The pipe gets air in it. When the pump next starts, the water coming up pushes that air up, thru the check valve, and into the "galvanized"/ "conventional" pressure tank.
Rbridges
Georgia
thanks. Will it hurt to leave a schrader valve in for a day or two until I get a snifter valve? It was spraying water every time the pump cycled. And thanks for your help.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
As reach4 said, the only difference is possibly the strength of the spring and even at that, there is no standard as to how strong the spring would be so there is a chance a schrader valve could work. Worst case, it doesn't make air for the HP tank but it should take more than a few days for the tank to waterlog.
