Help with trap configuration
thebordella
Ithaca, NY
Hi,
I have nearly completed my (first) half-bathroom renovation: new floor, new paint, new toilet, and...new vanity? Almost.
When I removed the old vanity/sink, I cut out the old trap. As advised by members on this forum, I then cut back to the drain pipe coming out of the wall and attached a standard P-trap.
However, when I tried to rough in my vanity cabinet, I discovered that the P-trap hangs too low to clear the lower shelf of the vanity. The wall pipe itself clears the shelf but the downward hang of the P-trap is about 3 inches too low.
Whoever installed the (very old) vanity/sink that I tore out seemed to have encountered the same issue. You can see their solution in the first attached picture -- notice that there is an elbow on the straight wall pipe which turns up, then straight, then right, and then into what looks like a typical P-trap.
If I recreated this configuration it would clear my vanity. But it looks non-standard. Then again, I am very new at all this. Can anyone describe what they did here and whether I could re-create this configuration?
Note that most of what you see in that picture is long gone, having been torn out.
The second photo shows the P-trap I added (before redoing the room -- it looks much nicer now!). But it hangs too low for the vanity.
Appreciate your thoughts!
thanks,
Aaron
drain
Is that a backwater/check valve? If so what is it doing there? IF you do not raise the drain in the wall, and that can be difficult depending on how the pipe is arranged in the wall, ALL you can do is cut a slot for the trap to hang into.
thebordella
Ithaca, NY
Apologies for my ignorance -- I don't know what a backwater/check valve is.
The only two valves I am familiar with in that first picture are the hot and cold cutoff valves.
I could cut a slot in the new vanity for the low-hanging trap, but before I do, I thought I'd ask about the old configuration. More specifically, what's wrong with it? Why can't I do that? (Again, asking this totally naively).
-Aaron
Gary Swart
Yakima, WA
In the second photo we can see some kind of an extra fitting/device in the drain line. It appears to have a cap on top which leads us to think it is some kind of a check valve. It should not be there.
Dlarrivee
Canada
-Aaron
It's an s-trap, and could possibly siphon the trap dry.
Inspektor Ludwig
Journeyman/Inspector
In the good ol' UPC
That little white thingy on the trap arm is an "anti-siphon" port of somekind. I think it's just a built in Studor vent. But beware.....there's some new products that are trying to get approval in my jurisdiciton. I don't know the names but it's a swing check trap arm that "eliminates the sewer gas smell caused by faulty trap primers and dry traps". It eliminates the trap. I've seen two versions, one goes on the tailpiece of a floor drain and acts like a spring check, the other is designed to go on the trap arm of a sink or lav. Any other plumbers seen these?
We said "NO WAY" thank goodness but every few months they try again. For the trap issue, as the guys said earlier, you'll either have to open the wall and raise or lower the waste inlet or you'll have to cut into the shelves to make room.
"thing"
IT is NOT an "S" trap, and from its appearance it is NOT a Studor or similar vent. It LOOKS like a backwater/check valve, but if so, it is NOT a replacement, or substitution for a trap. It is an ADDITION to the trap, and a poor idea at best. It also has NO function, unless there is also one on the toilet to prevent backflow flooding.
Geniescience
Homeowner
.... hangs too low to clear the lower shelf...
Please define "hangs too low". Your image #2 shows a P trap at the right place.
From there you can Route Your Pipe any way you want, to reach the sink. So you could send a pipe straight up, to a tight elbow, and then over horizontally to another tight elbow under the sink drain tailpiece.
Also, do you know that a P trap can double back on itself? It doesn't have to look like the letter P on its side. It can be a squiggle. You can turn the J part of it back towards the back wall. Try this, if you want to get the riser pipe to be located closer to the wall.
Hope this helps.
Inspektor Ludwig
In the good ol' UPC
AHA! I knew I had seen that trap thingy before,
it's a Genova "NovaVent" Anti-Siphon Trap. Google it and you'll see what "innovative" ideas plumbers are up against.
Doherty Plumbing
Journeyman & Gas Fitter
Penticton, BC
www.facebook.com
I have seen the spring type checks you speak of for floor drains. They actually work quite well. Are they ideal for areas where a trap primer would work great? No. But they're good for situations that warrant their use.
The other type I have no seen.
Inspektor Ludwig
In the good ol' UPC
Terry,
thanks for adding the pic. I'm a certified computer dummy. I really thought all the clicking and copying garbage I was trying to do actually worked! LMAO:D
NHmaster
S. Maine
The ACE hardware store sells them, HD and Lowes probably do also. Are they code compliant? Unfortunately......................................................................................... yes
Inspektor Ludwig
In the good ol' UPC
D,
I just read your last post on here, I think we were talking about 2 different things. The anti siphon on the trap arm is the one I'm talking about. The ones that go on the tailpiece I think provide a good answer to floor drains that have a dry trap problem.:D
Doherty Plumbing
Penticton, BC
www.facebook.com
D,
oh ok. I can't remember even seeing an anti-siphon device in use on a floor drain before. We use the spring and bladder type.
novavent
They do not show pictures of their products, but state that the "NovaVent" comes in sizes from 3" to 24" which would not be appropriate for a lavatory drain.
ChuckS
Aurora, CO
I'm no plumber but I'd go with the previous guys solution. It appears to have worked and it's in the vanity so no one sees it.
