waves22
Hello guys - new DIY here, I've learned a lot from you over the past few months and managed to install two toilets, two sinks and faucets (roughed in by plumber) with no problems. But now I'm stumped. My plumber installed a Delta multi valve (rough in) several months ago and I finally finished the tiling, was looking forward to a hot bath. The valve is the kind with the stops that can be turned with a screwdriver. I carefully followed the instructions for the trim kit and installed the cartridge etc. then turned on the main water supply and nothing happens when I turn the handle on new tub faucet. No water at all. I've taken it all apart, looked at it, shook the cartridge, put it back together again, still nothing. What am I doing wrong? Do I need to turn the screws on the stops to open the water? The only thing that looks odd to me is the handle is about 1/4 inch from the round cover sleeve, I guess it needs that space to turn freely? Plus, the handle only turns about 1/3 of the total distance, much less than my previous one. Any ideas? Thanks a lot
