drain lines
Removing the sanitary cross would be a good idea.
Even with a fixture cross, newer toilets will skip across the fitting and water will surge up the other arm,
Which raise the water in the opposite bowl, and then when the water spills out over the bend, you lose a good portion of water that had been setting in the bowl.
I'm in favor of not using cross fittings at all when two toilets are being used.
Just to see what I mean, you can pull one bowl, and flush the other room.
You will see water coming up the other toilet arm.
Strange, but true.
vskerche
Kentucky
What to use if no cross tee?
Strange, but true.
Thanks again Terry, How then would I tie in the 2nd toilet. Would it be permissible to attach a 3x3x3 wye into the horizontal just downstream from the 3x3x2 wye? and can that wye be at an angle? see pic
