Burst pipe in wall
Bloomfieldct
I successfully (almost) installed a pedestal sink in upstairs bathroom. Turned on the supply line valve in the basement, and water immediately began pouring from the basement ceiling above the pipe. I assume that because I failed to turn the sink faucet on before opening the supply line, the pressure from the supply burst a pipe somewhere in the wall. I assume I now have to start opening the walls to find the break. But before I do I thought I'd check here to see if anyone has any thoughts or suggestions for this humbled DIY'er. Thanks
Ian Gills
Senior Robin Hood Guy
USA
Oh sorry to hear about this. You have to be really careful how you treat pipe behind walls when you are working on it from the front to avoid joints breaking loose.
Your only hope might be if the pipe that coming out of the wall is screwed into an ell in the wall. Perhaps this came loose when you loosened the shut-off valve?
I think more information and some pictures would really be needed though.
Either way, time to call a plumber now.
With DIY, you win some and you lose some.
Kingsotall
Plunger/TurdPuncher
Flagstaff, AZ
Certainly was not because you didn't have the faucet open when you turned the water on. It is odd that there isn't a shutoff under the pedestal but rather in the basement. Gonna need to know what pipes you are working with. Copper, galvanized, PEX, CPVC, etc.
Bloomfieldct
...With DIY, you win some and you lose some.
That's for sure! I'm resisting calling the plumber just yet (no real emergency here since it's a second bathroom, other than a bunch of guests coming for Easter weekend), until I'm convinced I have to. I'll take some pics.
Bloomfieldct
Funny, I assumed it was because of the pressure buildup with the faucet turned off, because I couldn't think of any other cause.
There is a shutoff valve under the sink, but I replaced the valves (went from cabinet sink to pedestal, and they were hideous) so I had to turn off from the basement.
It's all 50-year old copper piping. It's the cold water line, so there is a connection behind the bathroom wall to the toilet, other than that it should be a straight shot from the basement. I guess I may have jostled something loose when I was changing the valve??
faucet
The "pressure buildup" is the same regardless of whether the faucet was open or closed, OR whether you turned the valve on slowly or fast. You have some other problem and it may be very minor once you figure out what happened, because installing a pedestal lavatory does NOT break pipes in the wall unless they were already on the verge of breaking.
Bloomfieldct
Here's a video of the leak from the basement. My thought is that, since the water pours out so quickly after turning the valve, the source of the leak is close to the basement (e.g. behind a first-floor wall, as opposed to the upstairs bath). Note that the leak is only from the hole in the ceiling, not the visible joint. http://www.youtube.com/watch?v=LqIq07QE0xs
I loved the video.
I think you are right, the water source must be very near.
I wonder what a fish eye camera would do in the wall.
But then I've never had one either.
Normally, I make an educated guess, and then start cutting drywall.
Ian Gills
USA
I cannot think of a worse job that being a mini see snake.
Poor thing.
Bloomfieldct
Thanks Terry. My wife is hoping for an Oscar nomination for Best Short Film. Thanks everyone for your thoughts & suggestions. Once the family departs tomorrow I'm going to try to isolate the leak -- I'm encouraged by the consensus that it's probably at a joint. Fortunately the most likely area (according to my educated guess) is behind cabinets in the kitchen, so I can make some test holes without risking divorce.
Redwood
Actually for this job my choice would be the Ridgid See-Snake Micro...
The things you can see through a drill hole...
http://www.ridgid.com/seesnakemicro/video/
Redwood
I find it's a big help in finding leaks in some of the older multi story balloon frame homes. A lot of them a leak on the 3rd floor could first appear in the basement. It's a lot easier to sell the idea of drilling a few small holes in the wall to find leak instead of bustin out plaster walls in the 3 floors above to find it.
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
Mine is first gen of the camera. It works just fine, it just uses an old dial to turn on and adjust the intestacy of the light, instead of the push buttons. The newest one will take a snap shot for you and save it on an SD card.
Redwood
Same here...
The moment I first saw it I knew it was a tool I should have.
I never upgraded cause I figure there is no need for snapshots.
They know there is a leak when they call and once I locate where it is they will see it up close and personal soon enough.
Heck, I'll present them with the busted pipe if they want it!:D
SewerRatz
Chicago, IL
www.a-archer.net
Same here...
Sir / Madam, may I present you with your trophy burst pipe. Thank you for playing, that will be $$$$.
