Tub Slip Joint Leaking: How best to seal/fix?
PhilGhoul
Sinking Spring, PA
Hi all,
I found your wonderful forum and was hoping to humbly ask all your professionals opinions.
I just discovered this leak after a bath. The slip joint attaching the tub drain to the drain pipe. No matter how I tighten it, or position it, it leaks.
My main questions are is this the proper setup? And how would be the best way to seal it? Should I get a new slip joint ring? Or should I eliminate the corrugated piece to make it straight?
I apologize for the ugly drywall,
I just tore it apart in frustration.
Thanks,
Phil
yes its really not good that hose it should be pipe sorry Id re do it all. including the drum trap and install a p trap . that work should have never been covered in drywall its short term plumbing to have the corrugated hose
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I concur with JHY. Tear out and redo properly with all glue joints unless there will be a permanent access panel.
