Sewer vent relocation
Thetruck454
New Hampshire
I have I beam floor joists that are 16” o.c. and run parallel with the sewer line.
Sewer main line is 3”
Sink is 1.5”
Shower is 2”
Currently the shower is an alcove and the vent line is in that part wall.
Wall to the right of the toilet is an outside wall. Remaining walls are inside walls
I’m doing a bathroom remodel in my house and taking the part wall out and making the shower a corner shower with two glass walls and adding a second sink. Removal of the wall means I need to move the vent pipe.
Under the two walls that also run parallel with the joists on either side of the bathroom they doubled up the I beam joist. Due to that I can’t take the vent line and jump over to get up those two walls. My only choices are the wall to the left of the shower or the right of the toilet. The wall to the right of the toilet is an outside wall so that would be foolish to put the vent line there.
I can think of two options for the vent line.
1. From what I can tell just simply relocating the line to the left wall makes it too far away for code, but will it actually run the risk of siphoning the sink traps?
2. Another thought is I could take a 1.5” line from the two sinks and go inside the wall in the cabinet and up that wall and tie it into the vent in the attic so I don’t have any siphon risk. That would solve the sink, but is the shower still at risk?
The lav can't be downstream of the toilet without being vented first.
The lavs if run with 2" can vent the toilet. Two lavs need 2" anyway.
None of those drawings work.
Thetruck454
New Hampshire
That's interesting. The one that says current is how the house is.
Could you explain why layout b wouldn't work? It has both sinks tie into the vent up in the attic so their vent path cannot be plugged by the shower or toilet and therefore be siphoned.
