Runaway Thermostat?
PM5K
San Antonio, TX
Relief valve opened on my hot water heater. The water was very hot from the tap, so I turned the unit off and ran enough water through it to get cold water into it. I checked the valve to make sure it was working properly, and then tried to turn the unit back on, however it would not turn on. I reset the breaker on the thermostat and it came back on.
So it seems to me I have a runaway thermostat.
This is just a point of use Ariston 4 gallon water heater, just want to be sure before I go pick up a thermostat, because I suppose it could also be the element.
(Also it's just a small point of use unit so it's off until I get it fixed)
WyrTwister
Lubbock, Texas
The tstat only switched one of the two hots ( 240 VAC ) I saw a WH that had an element shorted to ground on the un-switched hot . Therefore , part os the element was apparently running / heating 24/7 ?
The big box stores carry a plumbers pack with upper and lower tstat and 2 elements . That might be the way to go ?
However , if yours is a 4 gallon unit , is it 120 VAC ?
God bless
Wyr
DonL
Houston, TX
I agree that a shorted element can cause the problem.
If they short they can weld the contacts on the thermostat.
Is that unit on 120V or 240V ?
Good Luck.
