question on leaking tub drain, can I get this part?
harveymasons
Hi everyone,
I have a 2nd floor tub that is leaking. the reason is this: on the tub there is a metal washer piece that sits on the tub against the drain it is slightly domed/dished (this is on the tub itself not underneath. It has come loose and actually broke and now there is about a 1/4 - 1/2 inch a gap between the tub and drain. Can I get a replacement piece? I am not even sure what this piece is called but it closes the gap between the cast iron tub andn the drain so now when the tub drains some water is getting into that gap and leaking down below. Home depot did not have.
Can you guys suggest anyplace or another solution? Also, what would I use to glue/seal it to the tub? Something that is obviously waterproof but is silocone good enough?
thx in advance,
harvey
drain
There are replacement drain "plugs". Unfortunately, they have many different thread patterns. Fortunately, however, there are two common ones, a narrow fine thread one and a larger 1 1/2" coarse thread model. If yours broke off it is probably the fine thread one, so hopefully the available one will fit your tub. THey usually come with a lift and turn, or push/pull stopper and a smooth cover for the overflow opening.
