JohnfrWhipple
BATHROOM DESIGN & BUILD
I'm helping out an online client this month in Ontario with a shower design. The design is a large barrier free shower with a custom ACO shower drain. The primary floor waterproofing membrane I had shipped to him directly by Noble Company and we choose NobleSeal CIS because of it's performance ratings and that it can be tied into ACO's primary clamping drain.
I build my showers a little different and prefer to keep my shower floor membrane in front of the cement board on the walls and not behind. I also don't like the idea of using a paper thin banding material for the corners to prevent build up. Walls and floor move. You need a thicker membrane and need to plan on movement in the design.
I like a full sheet in the shower. One piece. And folded corners.
This week I asked my client to read my practice discussion on folding corners and I pooh poohed his wall prep. He missed the 1/4" cement board step. So I gave him two homework projects. One was to remove a triangle in two corners and two to practice his NobleSeal CIS install.
Here are two photo's showing part of his completed homework.
Progress Photo
Concept Drawing
Inside corner detail for NobleSeal CIS
This shower has solid blocking installed because we planned on this from the start. The backer board is Wonderboard lite. Later the plan is to switch out to Ardex 8+9 for the walls. I do not like membranes thinner than 30 mil's used for a shower floor. I do not like liquid membranes used for a shower floor. I do not like Ardex 8+9 used for a shower floor.
I like NobleSeal CIS or TS. This shower is using a ACO clamping drain. And an ACO linear drain. If you like the idea of one piece of waterproofing in your shower (you should) then practice at home folding corners. You can use this practice guide I made for a builder up North.
NobleSeal CIS Pull Check
1/4" WonderBoard Lite is test substrate
The other homework item was installing some 1/4" backer board in the corners where the NobleSeal CIS will be folded. I asked for a level mark be placed around the three walls of the shower 4" above the dry zone. The triangle you see below is roughly 6" wide across the top since we will be installing some Laticrete 3701 as or shower deck mud roughly 2" thick. The triangle allows two layers of membrane with thin-set be recessed flush with the wall. Now we have one ply of material on all three sides and no build up in the corners.1/4" WonderBoard Lite is test substrate
Progress Photo
Concept Drawing
Lots of issues shown in this one picture. Tape needs to be removed. Silicone around perimeter needs to go in. More screws on the plywood subfloor. Missing tape and thin-set on wall outside corner (not seen ion this photo). And the missing recess triangles (shown in concept drawing I sent back). Other photos showed other minor mistakes that we caught and fixed. When chatting and design a shower pictures are king. We can talk and talk but that wastes time and when you see something it makes more sense I think.
Are you confident about your shower build? Think you did a good job? Post your images here on Terry's site and let some pros have a look. Trust me it can be very humbling to have your work picked apart by your peers.....
