No water to Moen shower head
No water to newly installed Moen Posi-Temp shower head. This has never happened before. So I'm thinking bad cartridge? I run down the hill and pick up a 1222 cartridge for the Posi-Temp and no luck with it. Absolutly nothing comes out of the shower head. The next day I swing by my supplier and pick up a new valve body. I ask the plumber next to me if he ever encountered anything like that. His reply,
"Yes, that small hole can fill with solder."
What? Seriously?
"Yep. Done it."
So I pick up the new Moen 62320 valve and head up to yesterdays job. I shut down the water again, cut the valve out, remove the cartridge and try blowing air though the top port. Nothing. Absolutely nothing.
This time I solder most of the valve up on the horizontal, like I have done most of the time. I then put it up in the hole and solder very carefully the top joint.
It works perfectly now. So yes, the mystery of missing water solved. Don't use so much solder on a vertical joint at the top of the Moen Posi-Temp valve body.
That little hole that looks dark is the hole that supplies the shower head. Fill it with solder and nothing will come out.
The new Posi-Temp
And trimed out.
Here is a comment by John J Okeef,
"I'll admit i took the lazy way out i put the torch 2 the body and blew air thru the shower arm. It was me and a supply line."
John, I wish I had tried something like that now.
"Next time just take cartridge out and heat up body, you may get lucky, I did more than once"
"they should make the port a little bigger, it's ridiculous how small it is"
Christopher M.
BruceL
Virginia
Thanks for the lesson. As a DIYer I'm always a bit paranoid about soldering brass as it's more difficult than copper---the only solder fail I've had on my current project was a tub valve body I didn't get hot enough (trying to hit hot enough to melt solder but not too hot and damage the valve). But that one I could at least keep upright so the solder didn't flow into the valve. No chance to do this soldering a shower valve. Fortunately my kohler shower valve body uses threads instead :)
Bruce
FWIW, most of the shower valves with male threaded connections, are sized to allow you to use them as a fitting and the copper pipe will fit inside it perfectly so you can solder it. DIY'ers tend to use the threads, pros tend to use the socket and solder it (it's faster and cheaper - a bonus on both points).
