HereInOhio
I purchased a house that was built in 2010 and the previous owners removed the water meter (they embezzled $21 million so the legality of removing a water meter was not much of a concern to them....they needed the money). The water company is making me rough plumb a spacer in for them to come install a new meter.
I have 1" copper coming up through the basement floor. They want to install a 1" meter although the main shutoff gate valve has 3/4" coming off and the rest of the plumbing through the house is 3/4". I was just going to use a 3/4" threaded to 1" threaded adapter to install the new meter but due to the space and water pressure drop I'm considering replacing the shutoff with one that has 1" threads coming off. First question is do I need to use a gate valve or can I use a ball valve and is either preferred? Second question is it appears the main shutoff that is attached to the 1" copper coming out of the floor is some type of compression fitting vs. sweat, is this common?
Last question is I have an irrigation system that branches off right after the main shutoff. 3/4" from the shutoff to a 3/4" tee which goes to the irrigation (3/4") and rest of the house (3/4"). I currently set my irrigation timer to try to have the system off when I would shower in the morning and for the most part it is fine. Wondering if it would make a difference as far as the pressure drop if I was to increase the shutoff to 1", increasing the line going to the tee to 1" so: 1" in, 3/4" to irrigation, 3/4" to house? Will eliminate the pressure drop to the house?
If not maybe I'm better off just trying to fit in the adapter and leaving my current shutoff.
